my w reg city coupe semi auto stopped dead felt like the back wheels were stuck on it then didnt want to go into n or o ,when it did car still wouldnt move any ideas is it box or could the brakes be stuck on (wishful thinking maybe)tried jmping off but nothing thanks 2 all
city coupe gearbox
Re: city coupe gearbox
What happens (everything including display) when you turn the ignition on (position 1)
Does this change if you put your foot on the brake pedal?
Do the rear brake lights work?
Does the handbrake "feel off"?
Were you driving at the time? - did the rear end lockup whilst on the move?
Did it lock up during a gear change?
With some answers to the above we might be able to pin things down a bit.
It does sound (on the face of it) like the brake light switch has gone faulty, but it is possible for the clutch to fail and that might also produce the symptoms.
