451 AMT(Auto-Manual) Module
  • 451 AMT(Auto-Manual) Module
    The "new" 451 apparently has an additional Electronic Module between the ECU and the Gearbox.Can anybody tell me where this is situated on in the car?
    Anybody have the wiring connections for this Module?
    Re: 451 AMT(Auto-Manual) Module
    this is the transmission control module(TCU). the 451 has a separate control module for engine and transmission (ECU and TCU).
    The tcu is under the carpet on the lefthand side of the viechle. right under the seat. Remove the seat and seat console, and lift up the carpet and there it is.
      Hi Phingdoc, Fantastic,thanks a lot. I assume it controls the Auto-Clutch and the Gear-Box gear selector motor.Is that correct? Do you by any chance have access to the wiring,Interconnections,ECU,TCU,Gearbox and Engine for the 451? I realise that is asking a lot,but once again thanks very much for the Infos. kenjohn
        Yes it would be nice to have a wiring diagram for the 451...what are you planning to do?
        www.tune4performance.com
        ChipTuning - Remapping - Rolling Road
        Diagnostics - Key Coding - Tan Coding
        Tel:01923 773002
          Hi T4P(and of course Phindoc), Well.., I am an Electronics Technician,and I just hate not having a clear picture of "things"! So I thought for a start what is needed is a circuit,wiring,interconnections schematic covering the SAM,ECU,TCU,SE-Drive-Unit, Engine and Gearbox.Then move on from there.Unfortunately,I have only the wiring and interconnects for the 450 and not the 451! Maybe somebody out there has access to these Infos.
