I have added 3 grease points on the front wind shield wiper mechanism and cleaned and greased up wiper rod linkages. There is not sufficient wall thickness (only 3 mm) to fit grease nipples so I just drilled 2 mm diameter holes and use an Oregon chainsaw bar grease gun to inject grease.
Both pivot bearings for the two wiper arms were bone dry.
By the way, the 3 wiper rod linkage arms are surprisingly cheap - only GBP 20 from the dealer for a set. These were fine on my Smart even after 9 years and 150000 km possibly because I have been spraying grease onto the plastic bearings whenever front panels have been off.
There is only one way to maneuovre the wiper mechanism out: Both shafts for wiper arms have to be removed first. Otherwise impossible to remove mechanism. I manouvred the mechanism out towards the left. Had to unscrew expansion bottle cap and disconnect windshield washer pump to provide additional clearance.
