Hi please help me, I have posted this before. But I am still not understand. does anyone has a picture describition of where are all the holes needed to be connected? The reason I am doing this is because my custom turbo. The boost is not working properly, it leaks. and I have check everything. and believed that the actuator cannot hold the pressure... so if anyone know please help me thank you
Changing 5 holes actuator to single hole actuator...plz help
Re: Changing 5 holes actuator to single hole actuator...plz help
You could try this:-
If you really believe your actuator can not hold a vacuum then you will need to test it. That will probably mean buying a hand operated vacuum pump with a gauge so you can apply a vacuum and leave the nit for a while to see if it fails.
Thank you... I will try that method, but where can I buy the hand operated vacuum pump?Originally posted by heinkeljb View PostYou could try this:-
