Today I installed gearbox and noticed that amounted pressure plate (before I installed it on the car).
Gearbox worked very hard to place (only draw of screws).
I hope that the vibration motor to line up.
If you slip , only if the clutch is again reset to solve?
You can see that cam tension springs are fully extended. I held cam ring in position with a piece of haywire, see below photo. You have to hook it on such that it can be removed once pressure plate is firmly pressed home into flywheel.
Special fixture made from a 30 mm thick medium density fibre (MDF) worktop, 12 mm coach bolt and nut from a 9 inch angle grinder. You will see from below photo how the fixture works. Clutch assembly mounted on the special non Lidl fixture is placed in my DIY 10 tonne hydraulic press. It is impossible without the fixture to press pressure plate housing fully home in flywheel.
Obviously you need to do this in stages by turning the clutch assembly unless you have some means of spreading the load evenly so you can push pressure plate housing home in one go.
Flywheel is original from 2002, has seen 200,000 km. Wear is minimal.
? However, this method covers 450 petrol I guess.
