Hi everyone
I've owned my 2010-plate Passion fortwo CDI since January 2012 and have done about 50,000 miles in it since – and have loved every mile!
However, maybe 1.5 years ago the car started suffering from a seemingly random problem which would shift the gearbox into 2nd gear, forcing me to stop the car. To 'reset' the car I would have to turn the engine off, switch the ignition on, play with the gearstick (go into R, N, 1st, R, etc) until the 3 flashing lines appeared (during which time the gearbox would make continuous gear-selection noises as if it were rapidly changing through all the gears), then continue playing with it until the correct gear number/letter was displayed. The number/letter would still be flashing at this point, but the gear-selection noises would stop. Finally by turning the ignition off and on again the number/letter would stay solid (not flashing) and then you could start the engine and drive off.
This has been such an irritating problem as it does not seem to have any particular cause. I might be selling the car soon and I really don't want the next owner to have to suffer with this same problem ... also I would like to get to the bottom of it myself! Below I have listed everything that I know about this problem and you'll start to see how random it is ...
FREQUENCY
If anyone has any thoughts, pointers or suggestions of things to try I would be very grateful – as the thread title says, I really want to get to the bottom of this!
Just before I finish this post, I seem to remember there was a lot of debate and irritation surrounding a problem with CDI cars going into safe mode around 2012? It was something to do with wires chaffing or rubbing in the engine bay and the cars had to be taken to smart for a warranty repair to fix the issue? My car had this 'fix' before I bought it, but given how random this fault seems to be, do you think this dealer modification might require a revisit? What was the 'fix' exactly? Can I look at it myself?
Many thanks for your help and have a wonderful Christmas
David
FREQUENCY
- Happens much more often in cold weather, and even more so in wet weather. Very rarely happens in the summer.
- Only happens within the first 0-10 minutes of driving or so, and from memory only whilst the engine is still getting up to temperature.
- If it's happened and I've had to stop to reset the car, the problem will generally not manifest itself again during the rest of that journey – no matter how wet or cold it is. Occasionally it's happened twice in a row, but more often than not, once it's happened on a particular day it won't happen again.
- Does not coincide with changing gear, accelerating, slowing down or any particular speed. I could be cruising along at 10, 20, or 30mph, accelerating or having just changed gear and it could suddenly happen ...
- After the engine goes into 2nd it does not allow me to change gear until I've 'reset' the car. If I stop the car and try to move off again the gearbox will stay in 2nd making the clutch slip like mad to get the car moving.
- Very rarely manifests itself if I'm travelling more than about 30mph. On the few occasions where it has, and the engine can't rev fast enough to allow 2nd gear, the gear number on the dashboard will just start flashing. As soon as I go below about 34mph it will then drop into 2nd (I'm fairly sure this is what happens although it hasn't happened above 30mph for ages).
- I have a MisterDotCom cruise control fitted in-line with the throttle pedal, and also a MisterDotCom trip computer which taps off the car's CAN-bus inside the speedo housing (and is also connected to the cruise control). Both of these were fitted a week or two after buying the car and this problem didn't manifest itself for at least a year or more after installing them. If either of these modifications were causing the problems, why does it seem so dependent on the temperature / moisture in the air? If it was caused by either of these mods I would expect the problem to manifest itself regularly throughout the year.
- Apart from the MisterDotCom equipment and better speakers, the car is otherwise a standard Passion model.
- Both S2 Smarts and Smart Specialist Guildford have been foxed by this problem. When connecting their diagnostic computers to car, it does report back saying the car has gone into safe mode but it's never listed the cause. The MisterDotCom trip computer also allows me to look at error codes, but nothing is ever displayed when the problem occurs – even the yellow warning triangle doesn't illuminate!
- When I took it into Smart Specialist they cleaned the connector leading to the gear-selector motor and also put water-repellant grease onto the terminals in case this connection had somehow been giving glitchy feedback to the onboard computer. This didn't appear to make any difference.
David
