Yorkshire Devil, cheers for advice etc.
As soon as it goes limp again Im going to buy and fit the sensors myself. I have access to a mechanics workshop and ramps etc so it should be relatively straight forward.
Last time Merc did work on the car it was for a full engine drop to have the so called 'Fix' done for the power loss, replacement EGR and rerouting of wiring etc for sensor vibration.
I noticed recently as a result of this issue, that when they put the engine back in the car they failed to link the air filter holder with the connection to the side mounted air intake hose. Hence the car has been getting lots of dirt, water and dust and hot air in from the engine bay and wheel arch area instead of the cleaner air from the side vent. Ive changed the air filter and linked it up again, reset all the fault codes and surprisingly enough the car runs far better than it has since the original fix?
Im not sure what if any improvement clean air would make but seems to have done something.
