Smart Fortwo 2007 model 451 can’t unlock the door
  • Smart Fortwo 2007 model 451 can’t unlock the door
    My car battery is dead, my doors are locked.Using the Fob I can’t open the door and manually inserting the key into the door I can’t open it. What is the solution?
    Can somebody advise please thanks
      Open the rear hatch with your key, reach through & pull the door handle.
      That's what you do on the 450, so i'm assuming the 451 is similar.
      Good luck
        You can connect 12 volt battery to power one of the side door central locking motors. Remove bonnet to access wiring loom.
        Further details on Evilution’s site.
        Note you need to pay a small subscription fee to access that info. It is well worth it if you intend to keep your Smart and carry out your own
        maintenance.
          It is amazingly easy to break into a Smart 451. Makes you wonder why the designers made it possible to release bonnet from outside the car's cabin.
