TV touch screen ?
  • Re: TV touch screen ?
    Excellent stuff - what was the issue??
    Does the radio store stations after you have turned the ignition off and removed the key?
      I'm not sure what the problem was or why is was wired like that, I haven't had it in to find out long term but just testing it while it was plugged in the car I turnt it all on turn it all off,got out the car locked it got back in and turnt it all back on with the saved radio station in it so so far it's looking all good !
      Massive thanks you everyone who helped me in doing this ;-) happy happy happy,now just the amp wiring kit to install and then door speakers and done ;-D
      Sent from my iPhone
        Getting there, well done
          Yeah well happy so far, getting the wiring kit tomoz and hopefully the facia will turn up tomoz too. So it's just putting the door speakers in and running all the cables so if weather is ok seats out carpet out run cables JOB DONE
          Sent from my iPhone
            Well put the radio in today quite happy with it but........... Lol after fitting it then coming back to it later it hasn't saved the stored radio stations I put in it ? @problemchild ?
            Sent from my iPhone
              now change over the 2 x connectors as per earlier posts...
              plus you need the additional trim or a smartmods surround....??
                Ok cool I'll try that later ;-) and I no the surrounding got broken so need a new one that's ok thou no problem just have it looking tacky for a few days lol
                Sent from my iPhone
                  Ok so as iv been stripping back things to run the wires properly and easy this is under the passengers seat and saw that there is a bolt there that my ground will fit on nice and easy which is also being used as a ground wire this will be ok won't it ??
                  Sent from my iPhone
                    As long as it goes to bright metal it will be as good as any other earth you can find.
                      Sweet that's good to hear then just made earthing a lot easier cheers
                      One other question where does the the remote cable go on the head unit ?
                      Sent from my iPhone
                        Should be a wire, maybe blue/White May say rem on it
                        Looks like you're coming on nicely
                          The last picture you showed with the head unit wired in, but not slotted into the car shows a blue/white wire with a "BLUE" tag on it - that is the wire that is connected to the remote turn on / off of the amp.
                            black - switch for sub
                            red/blue - perm 12v (cable out to sub also)
                            brown - earth
                            grey/blue - lighting
                            grey/black - switched 12v
                            jj
                            Jj
                              Sorry problemchild have I said something wrong or asked what you have already said ?
                              Sent from my iPhone
                                After most of the day running my wires I found this hanging out and don't no where it belongs can anyone advise me please would say the ignition areas as the wire is too short to reach anywhere else ? Anyone ?
                                Sent from my iPhone
