Design changes
  • #46
    I don't have a handbag?
    27lennie.
    • #47
      neither do I lennie
      • #48
        A Handbaaaaaaaaag!!!!!Judging from all of these design modifacations/changes its a good thing we dont all have a 2CV.
        • #49
          More Mirrors inside and out <img src=icon_smile_big.gif border=0 align=middle>
          • #50
            That's too scary to contemplate!!!
            • #51
              A more robust rear wash system mines just bust big time water all down the inside!!!!!!!!!!!!
              • #52
                Yes the heater is rubbish, - Arthur never got warm on the commute to work today - but that's the price you pay for an efficient engine that doesn't waste a lot of petrol as heat. If you want to warm the car up quickly, keep it in a low gear so it's using the turbo. I got an electric fan heater that plugs into the cig lighter: absolutely rubbish, worse than useless. It makes a lot of noise and doesn't do anything.
                As for the front windscreen heater, if Ford have the patents for putting wires across the screen, why can't Smart put the electric heating element over the demisting fans so it can blow warm air straight away?
                The one thing I would change if I could would be the noisy fans. Does anyone know if it's easy to change them?
                Either there is something wrong or heaters vary per market since our heater works fine in -7 or so. (Mk 6 Cab). Keeps the car warm in 1C with the lid off even.
                • #53
                  I would really like to see that annoyingly placed button for the trip meter / outside temp, moved onto the wiper / indicator stalk (like in Golf's). Why on earth Smart have hidden on the left of the speedo is beyond me.....
                  Davey C
                  • #54
                    That's a good idea, would have to be the light stalk as the wiper on has the cancel/speed limiter set button.
                    Like the piccy in your signature. It;s the same as mine when I first got it
                    • #55
                      A glass rear window in the cabrio.
                      • #56
                        I saw paddleshift on the second page, and if that is the same as your gear with paddles on the stearingwheel (tiptronic, like formula one racing cars have) than that should definately become standard in a Smart. But widening the tyre size would be fine with me also, but then they should also widen the wheel housing, like on a Brabus. Or put the widening strips (Brabus also) on the car. And standard fog lamps in the front...
                        • #57
                          Fog lamps came as standard on the old ones, doesnt tiptronic just refer to the actual gear change as in semiauto with sequential change??
                          Mysmartnme, you do like going through the old posts dont u <img src=icon_smile_tongue.gif border=0 align=middle>
                          DD
                          • #58
                            <font face='Comic Sans MS'><font color=blue>I would like the rear view mirror higher up the windscreen, so i don't have to duck my head to look under it all the time!(just call me bob!LOL)</font id=blue></font id='Comic Sans MS'>
                            • #59
                              Mysmartnme if you have the wider wheels as standard then you will get the extension strips for the rear wheel arches.
                              • #60
                                Tougher Alloys!!
