The correct way to set the Clutch Actuator
  • The correct way to set the Clutch Actuator
    These are the official instructions from Merc for setting the Clutch Actuator.
    Personally I think they're a little overkill, but you know how exact the Germans like to be! So this is how the job 'should' be done!
    This should process should be carried out when the engine is Cold.
    1) Before the Actuator is put in place under the car ensure the actuator 'plunger' is extending 60mm from the housing. This is the plunger in the non-extended position.
    2) Put the actuator in place and loosely tighten the three E10 Torx bolts.
    3) Plug in the electric motor connector
    4) Using a 'Spring Balance' or appropriate tool push the actuator against the clutch with a force of 50Nm.
    5) While the actuator is being held against the clutch with the above force tighten up the three E10 torx bolts in the Specific sequence order of A, B and then C as shown in the diagram.
    6) Using the STAR tool carry out the "Pulse Clutch" routine from the MEG menu.
    7) If the 'Pulse Clutch' sequence doesn't perform correctly or is unavailable start the engine and shift between 1st and 2nd gear ten times. Then select reverse gear and turn off engine and ignition. This whole process needs to be done with the drive wheels lifted off the ground and with no resistance.
    8) With the spring balance still connected and maintaining a 50Nm pressure loosen the three Torx bolts carefully. If the 50Nm force is lost the whole process must be repeated from start.
    9) Gently relieve the force from the spring balance from 50Nm to 11Nm. The actuator will move back slightly. In this new position tighten the Torx bolts again in the specific sequence of A, B and then C.
    10) The clutch biting point now needs to be set. Using the STAR tool run the "Teach in clutch engagement point" option from the MEG menu.
    11) Set the point limit value by using the STAR tool and running "Program Point Limit Value" from the MEG control unit menu.
    12) Finally connect STAR diagnose and check for any errors.
    For a DIY guide have a look here.
    Re: The correct way to set the Clutch Actuator
    be interesting to hear the views of the independants that post on here with regard to wether they carry out this procedure or a n other?
      And for those people that don't have access to a star machine, or a newton meter , the usual way I'm sure will suffice until you get it to somewhere that does!!
        Good thread
        Defo worth the reasonable charge from a smart centre or indy which has access to doing it properly.
        If a job is not done properly, its not worth doing at all.
          How much is a reasonable charge as mine has started slipping..
            thats reason i put reasonable charge in my post
            There seems to be a regional variation on this pricing. I have experienced prices between £35 to £50...... others have had quotes for much more.
            I suggest a shop around and ask what you get for your beer tokens
            As a rule i have mine adjusted every service so it is bartered in the overall price.
              Following that whole process I imagine could easily take 30-40 minutes, where as a quick adjustment could only take 5 minutes. So you need to know exactly what you're getting for your money before you can decide if it's a reasonable charge. I would say £50 to do the whole process properly would be a good deal, where as £35 just to push in the actuator and guess it's position would be a very expensive 5 minutes work.
              I would imagine few places follow the whole procedure because of the time and effort involved messing around with Spring Balances and the like. I'm also sure it can be argued all day whether it's really necessary or not. But if you really want to do it properly then this is how!
                So RacingSnake, How are you getting on with your new Ferrari? Don't pretend for a minute you're missing your Smart!
                  LOL, it's not getting that much use in this tropical climate in which we live in , otherwise, it's all good mate
                  I do miss the smart massively, but thats more because my daily drive is a diesel landrover
                    Does your Ferrari get more attention than your Roadster did? (I'm thinking it probably does!)
                      it does and so far it's all good - but the thing is you can hear the ferrari coming about 5 miles away, the roadster you hear when it's 5 yards away
