Apologies if this is a dumb question, but can anyone tell me how you change the oil? It's a 2001 ForTwo/CityCar.
Oil change
Re: Oil change
You'll need a pela oil pump to get the oil out as the sump doesn't have a drain bolt.
Re: Oil change
CORRECTION:-
You do NOT need a pela 600 oil pump to pump the oil out!!!!
All you need is a SUITABLE oil pump, there are several types on the market, Pela just happens to be one manufacturer's offering.
I am not saying that the pela is not a good pump or that it is not suitable, just that it's not the one one you could buy.
Do some research for yourself on the Internet and just put oil suction pump into a search engine and go from there.....
Regards,
Re: Oil change
Here are some, for the money, I'd buy the 2.5 litre one and maybe empty it mid way!
Fudge!
fudge@fudgesmart.co.uk
www.fudgesmart.co.uk
www.sw-x.co.uk
Re: Oil change
Originally posted by cb3 View PostApologies if this is a dumb question, but can anyone tell me how you change the oil? It's a 2001 ForTwo/CityCar.
and of course, text here: http://www.fq101.co.uk/oilchangefortwo1.asp
