Smart Engine Light Stays On =( £1500 fix =(((
This topic is closed.
  • Smart Engine Light Stays On =( £1500 fix =(((
    The engine lights is on in my fourtwo (37500miles) =( The car is juddering and moving really slow. Its struggling to go above 3-4th gear 40mph
    RAC said it was the ignition coil, and the garage said that one of the spark plugs ends has blown inside and its going to cost £1500 to fix =(
    I only had A service in Dec and a standard remap with sports filter.
    Anyone had this problem before and suggest anything to help please??
    Thank you
    Re: Smart Engine Light Stays On =( £1500 fix =(((
    sounds like you now need an engine rebuild if a tip of a plug has knackered a piston
    there are two local smart independents
    Big Performance nr Heathrow
    smartarse n Watford (they'v changed their name)
    as well as fudgesmart.co.uk, who'll collect and deliver the car back after a rebuild with all new parts
    a decent rebuild should be c. £750-850 plus a bit extra if the pistons need replaced
    sigpic
    DO NOT FEED THE TROLLS
      I'll close this thread, since you've got another one exactly the same running in a different section!
