I've just changed the coolant in the Smart, and carried out a bleed of the system by removing the temperature sender. Now I have a problem, the sender isn't gripped firmly enough in the housing when the clip is replaced and is allowing coolant to escape past it. If I push down on it the leak stops, but that's obviously not a practical solution!
Any suggestions for a fix will be appreciated!
but given the frustration and annoyance of that bloody metal clip I was probably not being very rational! On the bright side I get to take that bloody clip off again. Yay.
