My sunroof is only opening just a few inches when it was working perfectly before. Iam a bit of a novice with mechanical things so I cannot understand why it is not working. I have checked in rear compartment to see if the fold down thing is at fault, but it seems to be ok. I would very much appreciate if anyanyone could give me any advice as to what the problem might be. Thanks in advance
sunroof problems with a roadster
Re: sunroof problems with a roadster
I would say that the runners need lubrication.
Most people have found that White Lithium grease is best and can be obtained from Halfords and other motor accessory shops in a spray can.
Apply to where the outer edges of the roof runners move through the roof bar channel then operate your roof a few times to work it in.I reject your reality and substitute my own
Proud to be a Smartie and very proud to have been married to a lovely lady.
This Moderator is ME
I know you said you checked the folding fault but have a look on every fold and push it out.
Have the engine turned on when trying to open it, sometimes that speeds things up and gives it moore o00mph.
When it has gone down as much as it can and stops, get out the car and check on the roof bar to see if its lifting the seal up and getting jammed.
Other than that, What Herman said.
make sure there is no grit trapped in the groves the roof runs along, this happens sometimes especially if greased heavily, also the sliders can break, whatever you do don't force anything.
hi every one,, my roof is doing the same thingbut it also compleatly stops at times if i keep pressing he button back then of then back and so on i can get it to go all the way back.im going to try to lub it up and see if that helps any
Originally posted by matcossy View Postok any ideas wat wrong with it tho
Originally posted by madDan View Postmake sure there is no grit trapped in the groves the roof runs along, this happens sometimes especially if greased heavily, also the sliders can break, whatever you do don't force anything.
Originally posted by smart_jimmy View PostI know you said you checked the folding fault but have a look on every fold and push it out.
Originally posted by herman1rg View PostI would say that the runners need lubrication.
Originally posted by westcoaster View PostCheck that it is folding properly.Fudge!
fudge@fudgesmart.co.uk
www.fudgesmart.co.uk
www.sw-x.co.uk
