smart not so smart
    Re: smart not so smart
    No it's actually you maggi that's full of ****
    ain't that the truth
    get back to your simple lego **** rubbish
      erm people HELPPP im only a student im in debt as it is and this car is killing me could it be an earth or sensor wire?
        That's why 2 new members in the space of about a month have asked you to stop with your awful posts that just have no useful information when all they asked for was some advice?
          it won't be an earth. It does look like a sensor to me, there must be another end somewhere that isn't connected. And it has to be in reaching distance. Where does it come from?
            i think it comes from the fuel pump because the adjoining wire goes to the fuel tank. however i was told i don't need it so ????? i ent got a clue
              should have gone to spec savers..... oops, i mean fudge smart!!
                The wire in the picture is there for the cars fitted with aircon it wont stop the car starting !
                does the car start straight away or does it take a lot of cranking to start ?
                steve
                  timing??
                  fuel starvation??
                  ECU damage??
                  sensor??
                  get it on a machine and read any fault codes!!
                    yer thanks for that erm i have to jump start it because the battery is a bit worn out of me trying to turn it over. but it does start and then cut off i ran a diagnostics on it my mate has a bosch one however it doesn't check if the immobiliser is on or off? so no fault codes except for can bus 1310
                      The immobiliser is off because it wouldnt turn the starter else
                      it must be a timing issue or fuel pressure problem . or a pipe is off causing a air leak does it run on all 3 cylinders when it starts ?
                      steve
                        It's going to be 1 of 2 things:-
                        Either Electrical
                        Or
                        Mechanical.
                        Does the engine suddenly die? Does it cough and splutter a bit before dying?
                        First version points towards electrical
                        Second towards fuel / air
                        There is a crank position sensor between the cylinderhead and the bell housing which might be at fault. It can get iron fillings attached to it which interfer with its operation.
                          When it cuts out, is it with the slave battery for jump starting still connected?
                          • #28
                            11:45pm please not being rude but if you can't help please dont just post non sense i honestly need help
                            Actually, he didn't post nonsense - he asked you in a jocular way to put your pics in an accessible way. You didn't! I can neither look at your facebook pics as I need to log in (as you, maybe?) nor do I want to join facebook to be able to look. Why not use a proper picture server like flickr or photobucket?
                            You may be frustrated with the car but that's no reason to come on here and start taking it out on the members.
                            There is a wealth of experience here, and, while posts do go off topic, you uploaded a link that none of us could look at and then expected us to be able to visualise the image from a login page to Facebook.
                            Now, back on topic!
                            Get your mechanic to foot the bill for the car going to a 'specialist'. It isn't your problem if it doesn't start after he 'rebuilt' the engine nor is it our problem that you're a poor student with no money!
                            sigpic
                            DO NOT FEED THE TROLLS
                            • #29
                              well yeah didnt pay him full amount because he couldn't get it started but yeah now i have to run around. its costing me way too much please is there someone who could help
                              Fudgesmart.
                              Who 'rebuilt' the engine?? I'm pretty sure there's no-one known for their smart knowledge in the Birmingham area.
                              non sense
                              neone
                              student
                              I rest my case
