heres one for you, got a 51 fortwo passion, 3 lines on the dash, connect the star to find out why, nothing showing on the faults in any of the meg/zee, when you turn on the ignition the clutch actuator does nothing, so ive replaced the clutch actuator that i know works, i try to teach the gearbox which obviously fails,i try to teach the clutch biting point but it fails, what do the 6 wires do on the actuator, i know the biggest pair are power for the motor, but what do the other 4 do???oh and how do i diagnose whats at fault, cheers guys
gearbox fault, good old 3 lines ahhhhhh
Re: gearbox fault, good old 3 lines ahhhhhh
check that wiring for internal faults/breaks , use a test lamp for this preferably, you've already proved the actuator on now is okay.
The other wires are for the fine adjust/feedback afaik.
Your star with Das gives you what should and shouldn't give power and whenWww.BigPerformance.Co.Uk
020 328 REMAP (02032873627)
07702948467
