Hi Guys
I was just looking at evilution site and there are some unfinished tests they started and cant see updates on them. Big P will know though!:p
i have a roady brabus and was reading about the following!
1) Forge silicone TIK ( http://www.evilution.co.uk/549 )
q) ass this is a silicone pipe not a hard plastic one does it flex underpressure? is there an aloy one made by anyone?
2) Vauxhall/Opel Z10XEP,Z12XEP or a Z14XEP Larger Throttle Body.
q) i see this is massive in comparison, but did it make alot of difference?
q) did the ECU cope with the extra air and get the mix right?
q) can the brabus injectors add enough fuel to benifit from it?
3)Janspeed Stainless steel Intercooler Pipes
q)are there an aloy version?
q)if i get the above throttle body will these pipes fit or are custom ones required?
these parts seem like nice cheap easy mods.. but without a remap can the ECU make use of this extra? i guess that this is all freeing up air flow so will increase responce torque and bhp also increase spooling the tubby.
idea's and info would be help full if anyone has gone down this route with any of the above and had problems or dyno results?
ps i will be taking out the rubish blanking plates in the exhaust pipes!
