For the first time ever, a fan at the front of my 52 plate, 450 passion will not shut off.
This evening on arriving home, a fan at the front continued to run after turning off the ingn key. Still running after 2 hours with the car parked up and engine off... It is not the heater blower. I had been running the A/C. Question, Does the 450 have a fan behind the Evaporator ? Is it controlled by a sensor. Obviously, disconnecting the battery stops it, but reconnecting restarts the fan. So over night i've left the battery disconnected.
Any advice is welcome please.
Since I saw you last, you've changed your screen name. I didn't realize who was giving the advice. Did you finish building your super car ? I'd love to see it sometime.
