Hello this is my first post here. I have a 56 plate automatic pink smart passion. Saturday I started having problems with gears with slow changes went to go out Saturday afternoon and my car wouldn't select any gears. So here's the situation if the cars ignition is on but car not started the dashboard tells me it's selecting gears 1st reverse neutral but as soon as the engine is running the car won't engage a gear and all I can hear is clonking. Help please.
Help please gear selection
It could be the clutch actuator needs adjusting, have a look here http://www.evilution.co.uk/index.php...engine&mod=331
Some people have had the actuator rod wear through the clutch release arm. http://smartmaniacs.co.uk/forum/the-...gh-clutch-fork
If it's not this i'm afraid it sounds like your clutch is knackered.
