More complications. Front panels must come off to run wiring and fit washer heater. The problem is the ambient temperature. Minus 5 C at the moment and my Smart is totally iced over. Risk cracking brittle front panels so this job will have to wait. Intend therefore to fit on the Trekka first. Although made by Renault, access to the washer system on the Trekka is remarkably good.
Some info that may interest Mottofree:
On my Smart 450 Cdi I have had the 150 Watt oil pan heater plugged in for 3 hours. Ambient temperature has remained constant at - 5 C. Surface temperature at top of engine - 3 C. Temperature at bottom external surface of oil pan + 10 C. Did not measure oil temperature as I wish my gauge to remain clean and not be soaked in black diesel engine oil. Surface temperature measured with a Fluke 62 IR thermometer.
