It is sufficient space.
The final version is with stainless steel washers :
- upper washer OD32mm x ID14mm x 1 mm thickness
- lower washer OD29mmm x ID14mm. x 0.5mm thickness
- rubber disc is OD32mm x ID13mm x 2mm thick.
The spring , press the upper washer , rubber disc pressing on the seat. Lower washer retain the rubber disk.
The discs do not require immobilization of one another as spring fastens them on the spot.
I understand what you are trying to explain but think you got upper and lower washer mixed up. Obviously upper washer must be smaller OD than rubber disc assuming up is direction where pin in wax element is pointing.
Up and down are relative terms.
I think that the thermostat was designed to work vertically but for some reason and after a hasty decision came as we know ...
Large washer is in diameter equal to rubber disc; since the thickness of the rubber disc is different of 0mm and settlement plan is tilted. Washer stainless never reach to seat.
Happy new year!
Today bonding elements disc with red silicone (washers together) . Monday we process the housing for easy closing, seal is a rubber-ring and requires little clamping force.
And this year the site says "Invalid File DSCFxxxx.JPG" for any length, any format ...
Thanks to all who responded.
Since I than a Smart it's , actually the first .
snow today we went the first time. ESP lamp gurgled ... which ESP ? is a 450 from 2000.
Free things sometimes are more expensive than those that be payable . And Picasa is free ...
On this occasion, I changed and antifreeze. High front, airy but still do not have heat. To remedy, I want to inject directly antifreeze in the radiator heating, suspect the a cushion of air.
