This wretched thing is still giving me grief!
I've repaired the ribbon cable inside and horn and airbag are all ok now, I still however have the angle sensor fault and it will not calibrate it, I've been on diagnostics to check the read out of the sensor and its permanently on 0 leading me to believe its not picking it up, am currently checking the wiring as someone may have yanked the steering wheel off and damaged one of the wires.
However I have noticed there are a number of codes for the same fault which must correspond to a specific fault?
My specific fault is the one highlighted
