Chequerd Flag working rear disc brake
  • Chequerd Flag working rear disc brake
    Copyright Spotty Badger Productions
    Spotted yesterday on M25 run, sorry its not the greatest photograph, i do have more when i get time to sort
    Re: Chequerd Flag working rear disc brake
    Ooh Ooh how much how much??
      Me or the Disc ?
        We all know how cheap you are Tom, i meant the disc conversion
          I suggest fitting some locking wheel nuts on those alloys
            That was a really nice set up! and looks so simple once you "know how"!
              I now know what i want next for my car !
                Big P also does a rear disc conversion, not yet seen it? I'm currently working on my own DIY version.
                  CF's kit was a custom over-sized front and rear set costing £1800.
                  The company that made them is 1 minute walk from my house.
                  I will eventually do a fitting guide for these kits on my site including a price and place of purchase for a standard size rear brake disc kit.
                    Not sure from the photo that they have retained the original drum for the handbrake, only adding the disc between the drum and wheel? Then it's just a calliper hanger and a pipe re-route - simple!
                    I want to do away with the drum and back plate altogether and use a combined brake/handbrake calliper from a Ford Focus. Much lighter and the inertia resistance is reduced.
                    Looking forward to your fitting guide for more pictures.
                      I can confirm having looked at the setup yesterday (fudge and i have looked thoroughly!) there is no drum behind that mahoosive disk, the handbrake is a cable affare and works with the caliper (or as part of it!) it looks very impressive and simple too!!!!
                        Is there a brake bias adjustment? I'd hate to think in an emergency, the back end tries to lock up, making the car unstable? I know the ABS kicks in. Good for handbrake turns though!!
                          I didn't get a chance to "fully" examine the set up, but as I've posted it looks impressive and simple to fit, there must be some kind of bias adjuster? isn't there?
                          Fudge!
                          fudge@fudgesmart.co.uk
                          Engine Rebuilding - sw-exclusive Remaps - TAN Codes - Key Fob Coding - Servicing
                          All Services Available Mobile, Key Coding Available 24/7
                          www.fudgesmart.co.uk
                          www.sw-x.co.uk
                            Are these the Hi Spec ones??
                              yep
