Am I missing something (or has this been asked already) but the ability/option to go straight to the last page of a thread appears lost?
Yesterday if you clicked the last posters name it would go to the last post (instead of their profile as you would expect)... however today I see the return of the small double arrow to take you to the last post - so this should be ok now.
Just noticed today, if I click 'quote', and reduce the quotation to the relevant bit, then add my comment below, it will let me backtrack in my comment to put in another letter or spelling correction (as normal), but when I type the letter it goes in at the end of what I have written so far (not normal).
To correct spelling, I have to remove my comment back to the spelling error, and then retype it all again.
This does not happen if just replying as normal, without edited 'quote'. (I am on Windows 7 and Chrome browser)
Not sure I understand?(test) I've deleted a line of your quote, added in this bit of text, then what? click back earlier in this comment and add in more text?
Which is what I did with the (test) comment up there? or have I missed the scenario?
Don't know, I've checked the usersettings, and registered users can upload custom avatars.... I've also 'rebuilt' the Avatar thumbnails, but that doesn't seem to have done anything either.
I'll have a more in depth look at the settings to see if I have missed anything :S
OK, I see, the standard avatar selections have not copied over correctly, therefore if you're using a standard avatar it will appear blank.
Will need to wait for David to sort that one out, as I guess they're all hidden on the old server.
No worries I'll do a custom one (the one showing looks nothing like me!)
Strange the difference they make - principally in clocking who's post it was I just read as I head into the following one.
not exactly clear though - something at the top of the page would be soooo much easier as sometimes you only want to go to the last page and not the last post to see how its developed.
Not sure I understand?(test) I've deleted a................ or have I missed the scenario?
I have tried this again with your quote above, and deleted part of your quote and added '.........', and then typed in my own comment below the quote, and went back and adjusted my own comment for typos, and same problem, the letter I type in middle of my comment, jumps to the end of my comment. weird!
All I can think is that there must be a glitch at my end on my computer, if I am the only one having this problem.
I will live with it, as its easy enough to delete and retype.
