Originally posted by 10:45PM
View Post
Upgrade thermostat
Sorry I do not know English grammar, I speak another language.
10:45, you're xenophobic or ...?
Now ambient temperature is +10 degrees Celsius, more than 3 dots does not raise the temperature.
@10:si ceva
Zi draq daca ai ceva cu mine sau taci in plm .
I solved the match. https://plus.google.com/photos/11282...18205146693954
At this thermostat (Wahler) I want you to mount a bypass solenoid valve and bypass internal to cancel. https://plus.google.com/112827018205...18205146693954
Solenoid valve will operate as follows (in principle):
- From starting the engine up to 90 C - closed
- From 90C up to restart the engine - open.
- A button for enable (for maintenance ,eg change coolant)
But ' Something is rotten in the state of Denmark! ' ...
You are wrong there. Its only purpose is to ease bleeding air out of system when cooling system is being refilled.
For the petrol 450, a poor aftermarket pattern copy is now flooding the market. Being sold by lots of UK motor factors including Eurocarparts and Carparts4less. This thermostat has the check valve fitted wrong way. Bleeding air becomes tricky and engine will take a very long time getting up to operating temperature because check valve is constantly loosing heat to radiator.
